I connected a NoLand RS11 to the NMEA 2000 network. Getting tach readings and water temp readings for both engines but no oil pressure readings - not even a needle showing anywhere. The NoLand unit is reading the voltage off of the gages correctly. Are there any known engine parameter issues for oil pressure or did I miss enabling something. TZT14 and Noland both set up for PSI units on oil pressure.
