Need to connect NMEA-0183 Auto Pilot and Flowscan. Manual and tag on cable shows White is TD-A and Blue is TD-B, which would indicate two output ports. Unclear what is NMEA ground, so I contacted Furuno Support and got the following, which contradicts the manual:
White (TX+)
Blue (TX-) also referred to Common or Ground
White (TX+) will connect (RX+)
Blue (TX-) will connect to (RX-) also referred to Common or Ground
I'm inclined to believe Tech Support over the manual and cable tag since in the marketing material specs they mention 1 NMEA-0183 output.
Has anybody made these connections and confirm? The manual is a bit lacking in the description of these connection functions like the power switch functions (purple & brown) and I just want to be sure.
Thanks!
White (TX+)
Thanks!
