I received the 10F Furuno (Airmar) pigtail Air 033-333. it appears this is not quite a color-for-color splice.
Just to back up a second, I am attempting to connect a Garmin 6 pin B260 (Garmin part # 010-10640-00, Airmar part # 91-721-rev04-b) to my brand new FCV588. For your convenience, a wiring schematic for the Garmin Airmar B260 6 pin transducer is attached here as a PDF.
On this Garmin B260, just like on the Furuno B260 (526TID-HDD), the green and red wires are cut off at both ends, and the INNER bare is also cut off inside the transducer. However, in addition, on the Garmin B260 (unlike the Furuno B260) the BROWN wire is ALSO cut off at both ends.
The 10F Furuno pigtail has NO orange wire or connector on pin # 5, so I am assuming XID is either not supported using the 10F pigtail or it is not important? If either of these is true, then do I just attach the outer bare to the pigtail pin #4 to support thermistor function?
I am thinking this is correct:
Furuno 10F Pigtail pin # -- Garmin B260 Wire Color
1 -- unused
2 -- unused
3 -- unused (or jumper to pin 4?)
4 -- outer bare (thermistor gnd)
5 -- unused (there is no pin 5 wire on this pigtail for XID)
6 -- unused
7 -- white (thermistor +)
8 -- blue (depth +)
9 -- inner bare (depth shield)
10 -- black (depth -)
Thanks (again) in advance for your help! Kyle
