Good morning Cameron,
Thank you for the inquiry.
It will not matter if you choose the B265 or CM265, they use the same high and low frequency elements. The only difference is the housing for the transducer ceramics. The "B" is a bronze thru hull, the "CM" is a cavity mount. You can choose either option.
Kind Regards,
