Radar antenna RSB 070 064 does not rotate
Bartcab
Hello everyone, I have a Furuno RDP 149 on my boat whose installation had never been completed. So I finished the cabling/wiring with the connection between the radar and the antenna. Since then I have not been able to turn the antenna. I think I may be missing the power supply which was not installed on my boat. Does the RDP 149 need to have a PSU 008 type power supply to power the amplifier and the magnetron? thank you very much 😊
The 10" NavNet displays (RDP149) do not need a PSU to power a 4kW open array (RSB0070-064). The combination you have is more commonly referred to as a 1934C or 1934C/NT depending on the chart type. NT = CMap
Thanks you for your quick answer and your help.
I'll have to find another explanation for this problem!
Thanks again
Philippe
I would recommend checking the settings to ensure that it isn't set for Monitor Mode.
