wkearney99
I'm interested in adding weather data to our boat's setup.
We've got four MFD12 units and various sensors. There's an FA-50 with it's own GPS and VHF.
The settings say there's a GP-320B on on COM1 of one of the MFD12s. I'm assuming that's NMEA0183. It also says there's an H2183 connected via CAN to the DRS_RADOME.
My question is would/should I be able to replace the GP-320B and/or the H2183 with an Airmar 220WX?
http://www.airmartechnology.com/weather ... tml?id=153
Or are the MFD12's able to only speak to the 320B?
And if the MFD12 will speak to the 220WX which network connection "should" I use? The 220WX supports both 0183 and 2k and I have sufficient cabling present to connect either way.
There's a SIMRAD autopilot on the boat and I believe it's using 0183 to the GP-320B. I'm assuming this would probably need to keep using 0183
There's also an H2183 on-board, connected to the radome. Would the 220WX be able replace the data provided by the H2183?
The boat was setup this way be previous owners. I have no information as to why it was setup this way. It seems odd to have both a PG-700 and a H2183, as aren't they kind of duplicating each other?
I'm assuming any changes here will necessitate re-running the MFD12 setups.
